I have a custom field that I am trying to show on my filter results page because I would like to export it to Excel. The problem is that I am trying to show the column "Zone", but there are quite a few other custom fields with the word zone in them (1st Zone, 1st Zone schedule, ect) to the point that when I type "Zone" into the search field under the columns drop down it shows all of the wrong fields and at the bottom says "10 more options. Continue typing to refine further." but I have nothing else to type.
Is there a way to show all the options in that column drop down? I really don't want to rename all the other fields if I don't have to.
Sounds like you're suffering from "fielditis" - a common affliction for JIRAs where unnecessary fields have been allowed to proliferate to the point where they start to clog things up. Ideally, you want to review your field usage back down to sensible levels.
But, in the short term, there's a little trick for this one - start adding the zone fields it is offering. It removes ones that have been added from the available list, allowing others to creep into it. Once you've found plain "zone" and added it, go back to the filter fields and remove the ones you don't want.
I want to see all the fields in the selectlist. I think this is a legitimate requirement. And it is also legitimate not to be criticized for it.
It is also legitimate to criticise poor practices, like allowing fielditis.
Your only option now is to rename the field to something more unique so you can find it. The workaround I wrote two years ago has now been disabled, as the drop-down no longer removes items already on the list.
Rename the field you are searching for.
