If is Filter issues, in de overview of the issues i need to add the columns labels, but i cannot chose it in het column-dropdown. How can i add that column? I need to do this, because i want to export to csv for analysis purposes.
Anyone an idea
Type a couple of first letters of your label field and you will see the field in the list.
I tried that and it works, but how about custom fields. Is there anyway i can get them visibible in the list?
You should also type the first letters of their names and you will see them.
Yes thanks that works too (not very intuitive method). Now that i have the right fields and i want to export them to CSV, i can see the label fields, but not the custom field. I use the export to CSV current fields). Any advice on that?
Never mind! I saved the query and when i tried again it works too!. Thanks for your assistance!
You should add the required custom field to the columns. If you export only the current fields, then all fields must be visible as columns in your issue result view.
Or you can choose the option to export all fields.
Yes, you are right. That is what i did. But even when the column was visible and i exported it using current fields, it did not show up in the export. Only after i save the query it showed up. thanks again!
I am glad to hear that it works for you. If my answer helped you, kindly accept my answer so, that other people with the same question could find this answer.
