Add custom field "Health" with colored dots red/yellow/green
Pete P
July 14, 2022
Is it possible to create a custom field (apps/plug-ins okay) that will display color instead of text?  Similar to the way priorities are displayed but we want one for health.  These would show up in our project plans and be easy to spot laggards etc.
2 accepted
Mark Segall
Hi @Pete P - You could create a custom select field with emojis as the options:
Pete P
July 14, 2022
That looks perfect @Mark Segall !  I didn't know emojis were available as options!
Like • Mark Segall likes this
Pete P
July 14, 2022
I used this site in case anyone needs them:
https://emojidb.org/dot-emojis
Like • Mike Keppel likes this
Matt Doar
Accessibility guidelines recommend not using color alone to convey information. Add a shape to the icons perhaps?
The 8.5% of men who are color blind will thank you!
SERVER
VERSION
8.22.2
