Hi Friends,
I have created the new "Epic" in my board, in that i need to add my closed issues. So i searched the issues in board but it is does not available. So can you please suggest if there is any options available to add the closed issues in Epic.
Karthik A.
If you are going to add already closed issues to an existing epic, you have to do a search for these issues and perform a batch update. Most likely you will also have to grant yourself the possibility to edit a closed issue to avoid reopening all of them (Jira usually do not allow you to edit closed issues): https://answers.atlassian.com/questions/50500/how-do-i-allow-jira-administrators-to-edit-closed-issues-without-reopening-them
