Add more fields to one issue type
Neil Shah April 25, 2019
I have some additional fields which i would like to add to a project.
However the project has different issue types e.g. bug, release, story, change request etc.
I only need to add these fields in one issue type called change request and they should not show in the other issue types.
How do I go about doing this?
Regards
Neil
Tarun Sapra
Hello @Neil Shah
Just to add to the answer of @Vishwas , if the fields are custom fields, then make sure the fields have the right project context configured in the custom field configuration.
Basically it's called adding the right context to the custom field. As described here
https://confluence.atlassian.com/adminjiraserver080/configuring-a-custom-field-967897356.html#Configuringacustomfield-contextContext
Vishwas
April 25, 2019
@Neil Shah
You need to configure Issue type screen scheme
First define a screen and add a fields that you intend to be part of change request. After that associate that screen with an issue type in that particular project. You will get a clear understanding about these when you refer the link that I have embedded above.
