Add ons compatibility when moving from JIRA softaware to JIRA Data Center
Vinay Ravi October 4, 2018
We have the system plugins installed in our JIRA software (server), and we are going to migrate to JIRA data center very soon. While checking Atlassian marketplace we got to know that some add ons are not supported in JIRA data center and we need to check with vendor for queries.
 The vendor states that it is possible to configure the same. Has anyone successfully installed such add ons, like:
Barcharts for Jira
Time to SLA
Toolkit Plugin for Jira
Also, are the below add ons already there in JIRA Data Center? Or do we need to install them separately, and how?
System Plugin: Tempo Planning API
System Plugin: Tempo Core
System Plugin: Tempo Accounts
System Plugin: Tempo Teams
JIRA Software Finnish (Finland) Language Pack
JIRA Software Chinese (China) Language Pack
Appreciate a quick response on this.
Susanne Götz _Tempo_
October 4, 2018
Hi Vinay,
The Tempo System plugins are bundled with the Tempo products ( Timesheets, Planner and Budgets) and do not need to be installed individually. Once you install any of the Tempo plugins, the Tempo system plugins will also be installed.
Susanne Götz
Tempo team
Jack Brickey
October 4, 2018
And I would recommend reaching out to the authors of each of the other addons.
Thankyou @Susanne Götz _Tempo_ & @Jack Brickey for the info.
Also, i would like to know whether "Create Issue on Transition" plugin by Luxoft can be made compatible with JIRA Data Center 7.12.
The plugin is not listed in Atlassian market place, we are only able to download version history.
Any help??
Thanks a lot!
Vinay R
Jack Brickey
October 5, 2018
That question has to be directed to the author of the addon.
Vinay Ravi October 7, 2018
Thanks a lot @Jack Brickey !!
Vinay
