Hi
I'm new to JIRA, but I'm struggling to work out how when you create a project, then add issues under that project, but I can't add it to our agile board. Every time I look at the agile board the issues don't appear in the backlog.
I can see a query filter when I go to agile boards, and the project I'm after isn't listed, but I can't see anywhere where you can edit the list of projects.
Discovered you have to be logged in as the user the originally created the board (in this case 'admin') in order to be able to edit the existing filter, otherwise you can only create new ones.
hey andy.
do you want to add this project to an existing agile board?
in that case you will have to adjust the filter the board uses.
when you say the project doesn't show up in the list where exectly are you trying to do so?
issue-navigator?
maybe here is some useful info for you
https://confluence.atlassian.com/display/GH/Creating+a+Board
you can edit the filter in the issue-navigator.
click the link "View in Issue Navigator" it will bring you there directly.
edit the filter and just hit "Save" when you are finished
note i edited...can be saved now
Hi
The problem is there is no option to edit the filter on the board. The text I'm getting in the 'configure board' shows
Saved FilterFilter for Java Dev Team<select id="ghx-filter-change-select" class="hidden"></select>
<label>Owner</label>admin
Thanks - I've discovered that the problem is that the filter was created by 'admin', not me, and Greenhopper was only allowing me to create a new filter. Once I logged in as admin the 'edit filter' link appeared and I could add the new projects in.
