Add screen while moving issues from backlog to sprint
NehaNagori June 12, 2017
I have too many tasks in backlog. I planned 3 sprints.
I want, either when I start sprint all issues must have filled defined criteria.
ex. I have task - create dashboard in backlog
When I move it to sprint It should show the screen of the checklist before moving it.
Nic Brough -Adaptavist-
June 12, 2017
This isn't something you can do without hacking the core code in JIRA Software.  The backlog screen is intended to allow you to move issues around the backlog quickly and easily, and simply doesn't have any code that you could even write an add-on to hook into.
The closest I can get is for you to exclude issues that don't match the critera from the board, so the users have to groom them properly before they appear in the backlog at all.  (For example, if you have a simple project board and a field called "list of tests" then change your board filter to 'project = X and "list of tests" is not empty"
NehaNagori June 20, 2017
Can you please help me in implementing the solution through the script?
June 20, 2017
There is no "script" for this.  Please re-read the first part of my answer.
