×I am an org and project admin. I have the default, basic Kanban board and I'm trying to add a column and status. I understand there should be a "Add status" button but there is none.
Can you please shed some light so I can set this up for my team?
Hi Christopher - Welcome to the Atlassian Community!
What type of project is it? Team-managed? Company-managed?
Also, is it a Software project or Business project?
Boards behave different based on the type.
Thanks John. Team-managed, software project.
Are you trying to configure this? Thats under configure board -> columns.
If not, can you send us as screenshot of what you see on the screen and where it seems missing?
Regards
Thanks for the screenshot. On the left you see you don't have more statuses.
You need to go to issue type-> workflow -> on the top you can add more statuses.
Then they will be available to put them in the board.
Regards
I tried earlier and saw the workflow, but it wasn’t clear where to create a new status.
Thanks Aaron and Jon. That is correct. My confusion was that the status categories (To Do, In Progress, Done) matched the actually statuses (pic attached). I was able to create a new status called "Backlog" in the To Do category. Thanks!
