I'm trying to find a way to add values to a single select list via automation or workflow. Is there any way to currently do this? I've searched but unable to find a solution so far. I found the following which matches my use case but am not sure how to implement: https://stackoverflow.com/questions/22892537/how-to-add-new-values-to-select-list-field-in-jira-dynamically-or-using-plug-in/23198416#23198416
Hi @David Loszewski ,
Using automation or workflow post-function are easy ways to accomplish what you are looking for.
Are the values predefined (always the same) or do they come from a different field?
https://confluence.atlassian.com/automation/advanced-field-editing-993924663.html would give you a hint on how to update a field with automation.
You can set the updated field with a permanent field, iterate an if-else based in some values so the field is updated based on another or copy value from another field.
The native post-function is a bit restricted on updating fields, so it will depend on which plugins you may have
@Samuel Bartolome I think your response assumes that I already have the values in the field. I may not have been clear. I'm trying to add an option/value to a single select list which, typically this is done manually through Issues -> Custom Fields -> <Field in question> -> Contexts and Default Values
I'm trying to accomplish the same thing through automation and/or addon script.
The following is my use case:
1. Single Select List Custom Field: Customers
2. Text Field: New Customer
When a person enters a form with a value in New Customers, I want that value to be added as a list option on Customers.
Not sure you can achieve that with automations, but probably you can do it with Scriptrunner as a listener maybe.
In Scriptrunner there is already a build-in option (on-prem) to update values of fields in bulk, so with that and the listener (if available in Cloud), it may do the trick
jira cloud -> automation -> action -> Send web request
Request URL: https://yoursite.atlassian.net/rest/api/3/field/customfieldID/context/contextID/option
Headers:
Authorization: ******
Accept: application/json
method: Post
web request body: Custom data
Custom data:
"options": [
"disabled": false,
"value": "new option value"
please refer to this link: https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Headers:
Method: Post
Custom data:
"options": [
"disabled": false,
please refer to below links:
Send web request with Automation: https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Help us plant more trees
