How do I Add workflow transition buttons in the JIRA cloud?
Buttons are deprecated in the new issue view in cloud. these have been replaced by simply clicking on the status and selecting the available 'to' status.
Seba
Yes. But takes to clicks, where the transition buttons takes one. So how do i add the transition buttons i want for each status? Is it under "Properties" and what do i add?
Transition names will be displayed under status fied:
yes, i know. However this still takes to clicks. That is why i would like the buttons.
I understand you but this was Atlassian decision to change UI. We can complain about it but it is like it is.
Seba
