Add workflow when workflow is assigned to 2 projects
adrian.hills November 10, 2020
I am trying to change the workflow for a project however, the project currently shares a workflow with another project.
Because of this, the "Add Workflow" button doesn't work, and the workflow I want to change it to is not listed in the "switch schemes" list.
How do I un-assign the workflow it is currently using so I can change it to the new workflow?
Tansu Akdeniz
Hi @adrian.hills
You can not assign workflow to a project. Project is associated with workflow scheme.
So, if you want to change the one of the project's workflow
  • Go to Issues -> Workflows -> Workflow Schemes
  • Create a new workflow scheme
  • Assign the workflow and map the issuetypes
  • Go to the project and switch scheme with new one.
You can also check this KB.
adrian.hills November 12, 2020
Thanks Tansu,
Working with the Workflow Schemes was the key. Now I have all my projects with the same workflow.
John Funk
Hi Adrian - Welcome to the Atlassian Community!
If the current shared workflow is similar to what you want to create, I would copy the current workflow and make changes to the copy.
Go to Settings > Issues > Workflows
Find the workflow and click Copy.
This will popup the new workflow where you can give it a new name and make your changes.
This will put the new workflow in an Inactive Status.
Then you will need to create a new Workflow Scheme and attach the new Workflow to that scheme.
THEN go to the project and switch the Workflow Scheme over to the new Workflow Scheme that you created.
