Adding User to group
Sam November 28, 2024
import requests
from requests.auth import HTTPBasicAuth
import json
from urllib.parse import urlencode
def add_user_to_group(base_url, email, api_token, group_name, user_name):
    api_endpoint = f"{base_url}/rest/api/2/group/user"
    auth = HTTPBasicAuth(email, api_token)
    headers = {
        "Accept": "application/json",
        "Content-Type": "application/json",
        "Authorization": f"Bearer {API_TOKEN}"
    payload = json.dumps({"name": user_name})
    query = {"groupname": group_name}
    response = requests.post(
        f"{api_endpoint}?{urlencode(query)}",
        headers=headers,
        data=payload,
        auth=auth
    if response.status_code == 201:
        print(f"User '{user_name}' added to group '{group_name}' successfully.")
        print("Group details:", json.dumps(response.json(), indent=4))
    else:
        print(f"Failed to add user '{user_name}' to group '{group_name}'.")
        print(f"Status Code: {response.status_code}")
        print("Error message:", response.text)
if __name__ == "__main__":
    BASE_URL = "http://jira.com"
    EMAIL = "example@gmail.com"
    API_TOKEN = "123"
    GROUP_NAME = "Testing"
    USER_NAME = "123456"
    add_user_to_group(BASE_URL, EMAIL, API_TOKEN, GROUP_NAME, USER_NAME)     I am getting 401 error can anyone help me in this
3 votes
Florian Bonniec
November 28, 2024
Hi @Sam
401 means permission error. You do not provide the right credentials. You should provide the credential as "basic {base64 encoded user:password}"
Regards
Hi @Florian Bonniec I am using token right! so need of password and it has permission also for reference .I checked this one The Jira Service Management REST API
Florian Bonniec
November 28, 2024
Did you follow this ? Using Personal Access Tokens | Atlassian Support | Atlassian Documentation
You are using Token but also referencing HTTPBasicAuth
yes,I tried without http basic auth also on that time i am getting 405 error
Florian Bonniec
November 28, 2024
This script works
import requests
import json
# Replace these variables with your JIRA instance details
groupName = ''
jira_url = ''
api_endpoint = f'/rest/api/2/group/user?groupname={groupName}'
url = jira_url + api_endpoint
# Your JIRA credentials
api_token = ''
# Headers for the request
headers = {
    'Content-Type': 'application/json',
    'Authorization': f'Bearer {api_token}'
# Data
data = {
  "name": ""
# Make the POST request to create the issue
response = requests.post(url, headers=headers, data=json.dumps(data), verify=False)
# Check the response
    print("User Added successfully.")
    print("Response:", response.json())
else:
    print("Failed to add user.")
    print("Response:", response.status_code)
Failed to add user.
Response: 405
Florian Bonniec
November 28, 2024
Most likely your base url is wrong. I tested it and works on my side.
Did you include the path if any ? like url/jira/rest....
