Adding a Help text in Custom Field in Jira
Akbar N October 30, 2018
I would like to add a help text just below a custom field in Jira. I want a similar one just like the User Picker custom field. Could anyone suggest how to achieve this ?
Mikael Sandberg
October 30, 2018
Go the the custom field and add a field description. Field Description is displayed beneath the data entry field when entering new issues and editing existing issues, but not when browsing issues.
Great. Didn't noticed i have captured it for couple of fields already in the screen. Thanks for the quick response.
Akshay Aggarwal June 1, 2020
The text is visible only when creating a new issue. I want the text to appear all the time under the particular field as i require the value of that field to be entered when transitioning from one status to another by an assignee.
Like Dave Liao likes this
Dave Liao
@Akshay Aggarwal are you on Jira Cloud, or on a form of on-premise Jira?
Akshay Aggarwal June 3, 2020
@Dave_Liao i am on jira cloud
Akshay Aggarwal June 8, 2020
Can somebody provide a solution to this?
Dave Liao
June 11, 2020
@Akshay Aggarwal - field descriptions are only visible during issue creation in Jira Cloud.
The default issue view in Jira Cloud doesn't support field descriptions (yet?) and editing all happens in-line.
One workaround is to switch to the legacy issue view (the "old view": https://support.atlassian.com/jira-core-cloud/docs/what-is-the-new-jira-issue-view/ ), but each user has to individually opt into the legacy issue view.
