Our company is currently using Sites for Google Apps and we are trying to integrate some JIRA functionality into the sites.
I understand that as both JIRA onDemand and Google Sites use the Open Social container, it is possible to simply put a JIRA gadget on a Google Site. I have done this by grabbing the JIRA Gadget URL and putting it on a Site. This works great.
Is there a way to automatically authorise, or remember, a gadget's permissions (instead of clicking 'Authorize' every time you view the site)? Also is it possible to remember a gadget's filters?
For example we will have a site for most of our major projects, and it would be good to have an Activity Stream specific to a JIRA project on each site. It is not ideal for every viewer to add a filter to view their project every time they open the site.
If someone could point me in the direction of the correct documentation, that would be immensely helpful. Google doesn't seem to be churning out any useful results.
Mitchell
Hi Mitchell,
It looks like Google Sites has some distinctive, non-standard requirements that may be interfering with the standard JIRA gadgets.
I've just read over the documentation for Sites gadgets and here's what I've found:
