if I use the standard "Label" in my Jira issues, the "Label" is automatically added to the filters above my backlog.
Can other label fields I created on my own be used in a similar way? If yes, how can I add those as filter in my backlog?
Thank you!
In classic Jira not New-Gen you can add a custom filter which appears at the top. not sure about new-gen though.
Any label you create will be in the label filter. I am not sure what you mean by "other label fields".
Hi Jason,
I created a new Field "new Label" in my issues.
While "Label" automatically becomes a filter in the backlog, "new Label" doesn´t ...
"New Label" will not appear in the filters at the top of the backlog because you have created a custom field called "New Label". Jira does not put custom fields as a category at the top of the backlog.
