Adding request participants in an automation
Lena Krauß August 20, 2021 edited
Hi everyone!
I am building a simple automation through which I want to add someone to the existing request participants (without removing the existing ones) when the status changes.
I tried two ways and both don't really work unfortunately:
1. Under "Choose fields to set..." I select Request Participants. In the field below, I select "Copy from issue" and the person I want to add.
When I test it, the automation overwrites the existing request participants and replaces them only with the person I wanted to add.
2. I tried the following JSON code (without selecting a "field to set" above):
Of course I replaced "internal name of the person I want to add". I tried it with the email, too.
The automation doesn't create an error, so I suppose the code is correct. But when I test it, nothing happens at all.
I would be very happy about some ideas why this doesn't work. Thanks in advance!
Lena
4 votes
Manon Soubies-Camy
Hi @Lena Krauß and welcome to Community!
Can you try the following JSON instead?
"update": {
"Request participants" : [
"add": {
"accountId":"xxxxxxxx"
You can find account ids by going to the user profile:
Hope this helps,
- Manon
Hi Manon!
Thank you so much for your answer. That works perfectly :)
Thanks again and have a great day!
Lena
Like 2 people like this
Manon Soubies-Camy
Glad it helped! :)
Peggy Miller
February 21, 2023
Can someone give an example of adding more than one participant?  I'm having trouble getting the JSON syntax correct.  TIA
Peggy Miller
February 21, 2023 edited
I figured it out:
"update": {
{"add": {"accountId":"xxxxxx"}},
{"remove": {"accountId":"xxxxxx"}}
Like 3 people like this
