Hi
Can we add the issue progress(percentage or GUI) in the gadget as a column or provide me a solution where I can show the percentage of the progress of the issue.
Thanks in Advance
Assuming "progress" means "time estimate vs time logged", then add a "filter results" gadget and include the progress field on it (and Σ progress if you're using sub-tasks)
Add Issue statistic gadget to your dashboard. you can either choose a project or a filter to restrict the output.
Select the statistic type as status.
You will be able to see the percentage of issue in various status.
