Adding tickets to an Active Sprint based on a Transition.
My Dev's have asked me if it is possible to automatically add a ticket to a sprint if they use the first workflow transition.
Not sure I like the idea but at least want to know if it is possible?
It's possible, if you have a scripting add-on, or are willing to write something small (specifically use a post-function that can work out the current sprint and add it to the issue). But on Cloud, no, you can't do it.
Of course, it's a total disaster in terms of planning, so your instinct to dislike the idea is spot on...
