Addition of two numeric columns
Stéphane Stiennon
August 5, 2021
I have a filter that shows some numeric columns.  I would like to add the value of some them to have one column that shows the addition  (in Rich Filter ?).
For example:
I would like to have a column that will add column 2 (TPD) and 5 (Dev Act Effort), so the values will be:
2
2
12
12
30
is it possible dynamically ?
2 accepted
John Funk
Hi Stéphane - Welcome to the Atlassian Community!
Are you using Server version or Jira Cloud?
You can use Automation for Jira to do the math.
First create a new number custom field. Then create a rule to add the two fields. I can give further instructions if this is the path you want to try.
Pedro Felgueiras
August 5, 2021
HI @Stéphane Stiennon
You need to have a calculated custom field.
You can check the documentation here:
https://scriptrunner.adaptavist.com/5.0.4/jira/scripted-fields.html
Best regards,
Pedro Felgueiras
priyanka naik
May 7, 2024
Yes possible
Register today
