hi.
I am trying to set to the comment value of custom field with Script runner post function "Adds a comment to linked issues when this issue is transitioned".
I am using:
<% out << com.atlassian.jira.issue.CustomFieldManager.getCustomFieldObject('customfield_10806') %>
But its return eror:
2017-12-01 16:25:47,812 ERROR [workflow.ScriptWorkflowFunction]: ************************************************************************************* 2017-12-01 16:25:47,812 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: IO-83, actionId: 141, file: null groovy.lang.MissingMethodException: No signature of method: static com.atlassian.jira.issue.CustomFieldManager.getCustomFieldObject() is applicable for argument types: (java.lang.String) values: [customfield_10806] at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.UpdateBlockedIssues$_doScript_closure1.doCall(UpdateBlockedIssues.groovy:112) at com.onresolve.scriptrunner.canned.jira.workflow.postfunctions.UpdateBlockedIssues.doScript(UpdateBlockedIssues.groovy:100)
Can somebody help?
Hi Taras,
Have you tried using double quotes on the cutomfield name?
Also, why don't you use Automation to add a comment on transition? That's more intuitive in my opinion and maintenance is transparent, doesn't require any sripting knowledge :)
Hope either suggestion will help!
Cheers
Understood, then you can't use the line above directly: CustomfieldManager is not a static class and needs to be instanciated. I'm not sure why you out the customfield value but I'm sure that you'll need more than this to use CustomFieldManager.
That would imply something like:
CustomFieldManager cfm = ComponentAccessor.getCustomFieldManager();
CustomField cf = cfm.getCustomFieldObject('customfield_10806');
Does that help?
Cheers
Sure, might be an option, let us know if it works!
