I haven't found this reported as an anomaly.
My problem is: I have a plan based on a filter with ±600 issues. The proejct has beed going on for a wile now, and the plan only shows 400 issues. 200 are missing; the investigation took a while as the plan configuration, "work items have been removed" is not showing the 200 removed because of the 30 days delay. See screen capture below.
I strongly believe the counter shall dislay the removed items because of the day count, as this has an dirrect effect on the included issue count if the days to remove closed is set to 1000.
Setting the days to 1000 in the removed issues, then the tab of "Work in your plan is greather"
@Philippe Bettez-Poirier
Below is suggessted fix according to me
Reference articles
https://community.atlassian.com/forums/Advanced-planning-questions/How-to-filter-for-Advanced-Roadmaps-Removed-Issues-or-delete-all/qaq-p/2532929
https://community.atlassian.com/forums/Jira-questions/Advanced-Roadmap-Plans-not-seeing-Done-items-that-have/qaq-p/2372581
Jayesh R
thanks for your answer, I already had my workaround by changing the numbers of days to remove closed issues. My pov is that what I'm reporting is an anomaly as they are not showing in the removed counter.
and the suggestion to correct it is recorded here: https://jira.atlassian.com/browse/JRACLOUD-96180
Probably I should have looked there for starters.
thank you again,
cheers.
