×Hi All,
Is anyone aware of how to do the following using a JQL ?
Searching for all the issues which are created today from 6A .
Note: Trying to create different dashboards for different teams who work in different shifts.
Team 1 (Shift 6A to 2P)
Team 2 (Shift 1P to 10P)
Team 3 (Shift 10P to 6A)
Thanks in advance
I got the solution which works for me.
startOfDay(6h)
it will show only todays issue, can you help to find the issues of whole month based on shift wise.???
The solution you are after are described in an earlier question: https://community.atlassian.com/t5/Jira-questions/Advanced-searching-between-hours-of-the-day/qaq-p/79989
Mikael wrote:
resolved > startOfDay("+8h") AND resolved < startOfDay("+18h")
it will show only current days issue, can you help to find the issues of whole month based on shift wise.???
@[deleted], sorry for late reply. I'm not sure what the criteria for your 'shift wise' is, but if you want to have the current month's issues returned you can use the JQL:
resolved = startOfMonth()
