We tried a CSV import on JIRA. The problem that arises is the CSV file reads (for a comment)
24/09/2015 17:22:26 ...........
While the comment added shows a date of 09/Dec/16
Can anyone help on this? Not sure what is the problem. We tried the same CSV on stage, worked just fine.
Thanks.
The / could be causing you problems. Instead try formatting your dates like this: 2012-02-10 12:30:10
It should comply with the SimpleDateformat: http://docs.oracle.com/javase/6/docs/api/java/text/SimpleDateFormat.html
Help us plant more trees
