  • Community
  • Q&A
  • Jira
  • Questions
  • After restoring database I get " GreenHopper is currently unavailable. This might be because an upgrade task has failed to run or has not not yet completed. "
Flacid Snake July 22, 2013
I've installed Confluence's database with the same user as Jira's database (great mistake!), so
Jira couldn't start properly. Now the Confluence's database is ok. For Jira, I dropped all the tables and set up them again. Everything's working fine, but I can't make Greenhopper available (I tried to uninstall it and reinstall, but it doesn't work).
Any help?
Thank you!!!
Flacid Snake July 24, 2013
What I did in order to solve the problem:
1. Uninstall Greenhopper from the webbrowser interface.
2. Stop Jira
3. Manually locate and delete the AO_60DB71_* tables in my Oracle
Database (using Oracle SQL Developer)
4. Manually locate and delete the AO_60DB71_* sequences in my Oracle
ScottC
December 8, 2015
Dropping these tables will delete all JIRA agile data. In addition, direct database modification is not supported.
Flacid Snake July 23, 2013
Logs uploaded!
Any help is appreciated
Timothy
July 22, 2013
JIRA logs will help.
