Sign up Log in
After upgrading to Jira Data Center version 9.15, I faced a color issue on the 'Look and Feel' page,
Murat Seven
April 26, 2024
Hi, I have installed Jira Data Center version 9.15, but I encountered an issue on the 'Look and Feel' page in the color section, which was not a problem before the upgrade. Upon investigating, I found out that it is a bug. Here is the link https://jira.atlassian.com/browse/JRASERVER-77608 . Which version should I upgrade to in order to avoid this issue? Could you please provide me with a version where I won't experience this color problem?
Many thanks,
Murat Seven
Brant Schroeder
April 26, 2024
@Murat Seven I do not see a fix for it yet on a newer release (9.15.1)   This being the case I would recommend just using the workaround for the time being.  I would suggest that you follow this issue so you can learn when it is fixed and what release contains the fix.
Workaround - https://jira.atlassian.com/browse/JRASERVER-77608
Break the white on white colors and set a different color for "Drop-down menu item - text color"
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
