Aggregate Numeric fields of Subtasks
Ray Balmeo Cagayon April 6, 2024
I have generated automation to create subtasks and assign test hours per subtasks.
  1. Task 1 - 4 Hours (Under Custom Numeric Field)
  2. Task 2 - 3 Hours (Under Custom Numeric Field)
  3. Task 3 - 6 Hours (Under Custom Numeric Field)
  4. Task n - 4 Hours  (Under Custom Numeric Field)
As the Tasks get completed, I will need to re-assign the values to Zero (0).
What I wanted to do is to calculate the sum of this hours and calculate it against a predetermined date and see if there is a risk of missing it.
is there a possibility to calculate the agregate of these numeric fields and add this to the current date and time to see if i still fall below my target date?
I only have one Custom Field (Test Hours) assigned to the subtask.
April 6, 2024
Hi @Ray Balmeo Cagayon -- Welcome to the Atlassian Community!
You mention automation, and so I am assuming you mean automation rules.
You also note both Task and Subtask issue types:
  • for subtasks, you could gather and sum the values with {{issue.subtasks.yourField.sum}}
  • for Tasks, you could use the Lookup Issues action with JQL to gather the issues, and then sum the field with {{lookupIssues.yourField.sum}}
Once the sum is available, that could be added to dates using the various increment functions:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-date-and-time/#Date-plus-unit---
Then your rule could use conditions for the tests you describe:
https://support.atlassian.com/cloud-automation/docs/jira-automation-conditions/
@Bill Sheboy
Thank you. I will give it a go.
Register today
