Agile Cards: Updating physical cards after updating task on Jira
krishan rampersaud
May 11, 2016
We are testing out your Agile Cards
When you update your tasks on Jira, and re-scan the board is there a way to know where a physical card needs to be moved to?
I tested moving a card in Jira then re-scanning the board, it shows the moved task in yellow, but does not indicate anywhere that it has been updated from its current position  online and needs to be moved to somewhere else. It just gives you the option to update the Jira Board in which case it just moves the online version back to where it was.
Magdalena Zacharczuk December 8, 2016
Hi Krishan,
Thanks for reaching out and sorry for the delayed reply on our part. It would be great to get some more details on your use case with the Agile Cards scanner. Could we get in touch? My email is magdalena.zacharczuk@spartez.com.
As for your question: under the photo of your board you should be able to see all the detected issues with information about the current 'physical' and JIRA status of every issue. Were you using the mobile or desktop scanner? They work slightly differently in some aspects.
I'm hoping to hear from you.
Magdalena from Spartez
Read the story
