Agile Error
Deleted user March 5, 2015
JIRA Agile is currently unavailable. This might be because an upgrade task has failed to run or has not not yet completed.
Please contact your system administrator if you continue to see this message.
t
WeAreAllJustinNow
March 9, 2015
Hi Amir,
The error message that you are seeing is, unfortunately, relatively generic.  My advice would be to open a ticket with Atlassian Support at support.atlassian.com so that we can take a deeper dive into your situation.
Nic Brough -Adaptavist-
March 5, 2015
First, try removing the addon, then reinstalling it.  If that does not help, then you'll need to read your log to find out what errors it is throwing.
