Sign up Log in
Agile Work Board loading slowly showing spinning icon
Ivan Kovnatsky August 22, 2013
Hello.
We expericening slow load of the particular Agile Work Board. Actual result is that it loads for about 10 seconds, while other boards loading normally.
If any additional information required I'm ready to provide.
Ivan.
Eddie,
Base card colors only set for:
* Task
* Sub-Task Task
Got few filters:
* Expired duedate < now() and status != "closed"
* Only My Issues assignee = currentUser()
* Recently Updated updatedDate >= -1d
Can these few configurations can lead to 10 sec board load? I've looked throught the configuration and found very poor customization. I'm guessing it might be JIRA reindex issue or possibly this: http://www.greenpeppersoftware.com/site/posts/list/609.page
Ivan.
EddieW
August 22, 2013
We ran into this as the result of using custom card colors based on JQL.
Have you modified card colors or anything else about the board?
Are some Quick Filters enabled that are slowing the board down?
Thank you for the response, will check with the Team.
Eddie,
* Task
* Sub-Task Task
Got few filters:
Ivan.
