We have upgraded JIRA Agile plugin from 6.3 to 6.7 version. After upgrade when we clicked on Manage Boards, the error in the attached file is getting rendered.
Could you please give an idea where exactly the problem is?ManageBoardError.jpg
image2015-3-25 21:1:31.png
I found the solution by tweaking some SQL changes.
Could you possibly be a bit more specific about what you had to change in case someone else runs into this issue?
I found the below two links are helpful in our case: https://jira.atlassian.com/browse/GHS-10771 https://jira.atlassian.com/browse/GHS-9991 We followed the workaround specified in the second link and it worked.
Yes Geert
Did you perform a re-index already?
