Allow Issue Collector to Notify non-JIRA user of submittal
John A_ Verlangieri_ Jr_ June 14, 2013
We have created an Issue Collector for our project in JIRA On-Demand. We created two custom fields to collect User Name and User Email and made them manditory so we can know who submitted the issue. The users want to know how they can get some response from the system via email that tells them that their ticket was successfully submitted. I would like them to be able to get another notice when it gets assigned and when it gets completed with the appropriate notes. How do I get the system to do that? Is it even allowed in On-Demand?
Paul Greig
June 15, 2013
Hi John,
This would only be possible if you were able to populate your OnDemand instance with the profiles of the customers that were encountering this collector.
When creating the collector there was an option you would have selected, Match Reporter?, you are able to set this to match the email address with OnDemand and the one used within the collector. The matching process is also dependant on the 'Create Issue' project permission being granted to this user or group membership of the user. Otherwise it uses the default reporter value.
If you met the above requirements, then you could update your notification scheme for the project and would add 'Reporter' to all of the events you would like the customer to be informed about.
Here is a great artcile about using the Issue Collector, https://confluence.atlassian.com/display/JIRA/Using+the+Issue+Collector.
John A_ Verlangieri_ Jr_ June 15, 2013
Paul,
Unfortunately, we do not know the profiles of all the customers who are using this Issue Collector. Right now we have created an ID to act as the Default Creator, but it isn't helping the reporters. Read the Using and the Advanced Using pages and they aren't that helpful for this problem.
So, what I'm looking to do is to send an email to a recepient that is contained in a custom field upon Assignment. Can I write code of some sort to accomplish this? We have Java developers who know more that I do, but I need to know if there is some experience out there that we can learn from before I ask for the resources.
Thanks.
Paul Greig
June 15, 2013
Thanks John,
The only method I'm aware of would require an user-installed instance and would make use of a Groovy script to perform the email post-function on the creation/event of the issue and then reference the custom field you are using to store the email address.
If you were interested about investigating this method further it is detailed here: https://jamieechlin.atlassian.net/wiki/display/GRV/Post+Functions#PostFunctions-SendEmailWhenBlockerReported
Otherwise, there may be some other helpful suggestions from the community :)
Deleted user November 19, 2013
Hello
We are facing a similar problem (notification to non-jira-user upon creation (or status transition) of issue) and I wonder if you managed to solve it with a Groove script?
Deleted user June 23, 2014
We also need the same feature too. How to automatically create a JIRA user using details from the JIRA Issue Collector.
4 votes
Vladimir Horev _RaleyApps_
Hi @Gabrielle Bautista [ACP-JA], @[deleted], @John A. Verlangieri, Jr., @Paul Greig - Gdansk, @Jacques Bosch
You can send notifications based on E-mail data from JIRA IssueCollector using our plugin: https://marketplace.atlassian.com/plugins/net.vacom.jirassimo/cloud/overview
Here's a detailed explanation on how to setup this kind of notification: https://wiki.raleyapps.com/display/RAL/Notifying+external+users
Enjoy!
Vladimir Horev
Jonathan Serra August 12, 2016
Hi @Vladimir Horev [Jirassimo],
I tried to implement Jirassimo to be able to send an email from a ticket, but putting `issueCollector.email` in "Email or destination list" field didn't work.
In fact, there was no value at all in `issueCollector.email`, maybe JIRA changed the way the collector metadata is build?
I'm looking forward, thanks.
Hi @Jonathan Serra
Please send me JSON output of your JIRA issue generated by Jirassimo to the email that you can find here: https://wiki.jirassimo.com/display/JIRASSIMO/Welcome+to+Jirassimo+AddOns+for+JIRA
We'll have a look ASAP.
Best,
Vladimir
Jacques Bosch
February 22, 2014
We have a similar requirement. Notifying non-Jira users who used the issue collector of status changes.
