Any 3rd-Party Tools To Export ALL Biz Project Data?
Michael P_ O_Hara June 11, 2024
Does anyone know of a 3rd-party that can run an export of all info:
- List details
- Comments within a list item
- All attachments
The problem at present is Jira has no method to do a data dump that an assessor would need to append to their certification (i.e. PCI-DSS, ISO, SOC2, etc).
I was surprised to hear this doesn't already exist as a feature.   The need is obvious.
Aron Gombas _Midori_
@Michael P_ O_Hara I am not totally sure what "list" means here, but I guess it is a list of issues.
If so, then the Better PDF Exporter app can produce you a precise PDF export that contains:
  1. fields
  2. comments
  3. attachments (embedded in the PDF)
...and a lot more like change history, linked issues, worklogs, etc. For example:
See some examples here: https://midori-global.com/products/better-pdf-exporter-for-jira/cloud/export-samples/jira-issues-pdf-exports
If you want to add details, remove details, then you can customize the PDF template!
(Discl. it is a paid and supported app developed by our team. Free for 10 users!)
