Any best practices or punchlist after a sandbox copy?
Alex Hall
Just curious if anyone is aware of a sample punchlist for after a sandbox copy is completed. My organization is just starting to create governance on our sandbox environment and currently don't have anything developed yet.
Some example things I know I need to address:
  • analyze user groups and make adjustments
  • export and import automation rules
  • reset banner and sandbox related branding
Gal Fatal
March 6, 2024
Hi @Alex Hall
I think you can find answeres to some of your questions in this article I wrote :
Navigating the Atlassian Cloud Sandbox . Take a special look at the "Copy data limitations".
If you need to compare you sandbox environment to your production site, I recommend you to use tools such as Salto so you can be sure about the differences. In this case Salto also provide the option to merge changes beween the sites, for examplem, Atlassian do not copy the automation rules when you copy data from production to sandbox. You can use Salto to compare and merge the automation rules.
Gal
