Hey guys
If you take a look at the screenshot I provided, you'll see a Filter Results gadget that I created to show only standard tasks (or what we refer to as "Jobs").
The marketing team at my company wants to see a filter results gadget that would show subtasks AS WELL AS the Summary field of its parent task.
Is this possible through JQL?
Hey @Sid,
Thanks for the reply! Unfortunately, that's not exactly what I'm looking for.
What I meant to say before was that I want to create a "Filter Results" gadget that would show subtasks (and fields of subtasks), as well as the "summary" field from the parent issues of the subtasks in the same gadget
I get that this solution would display the subtasks of parent issues, yet I want to see other fields within the linked issues...if that makes sense
Hi @Ian Balas,
If you want all the list of parent and subtask - you can use "Project = MAR", if that is not you are looking for this thread might help - https://community.atlassian.com/t5/Jira-questions/Searching-for-subtasks-of-parents-that-meet-certain-criteria/qaq-p/39736
