  • Community
  • Q&A
  • Jira
  • Questions
  • Anyone use the Jira Cloud / Slack integration? How do you add required fields to when you create?
Ian Johnsen February 5, 2020
Anyone use the Jira Cloud / Slack integration? How do you add required fields to when you create? Looks like only summary and description is available. Is this the case?
/jira create
image (1).pngimage (2).pngimage.pngScreen Shot 2020-02-05 at 10.12.47 AM.png
David Michelson
October 14, 2020
@Ian Johnsen I have good news! The Jira + Slack integration now supports creating issues with required fields! Before, you could only add a Summary and Description, but now the integration can dynamically pull in fields from your project/issue type so that you can fill in those required fields straight from Slack.
Give it a try and let us know what you think! Just use /jira create in a Slack conversation.
As a caveat, we have solved for most types of required fields in Jira, but there are still a slight few that are not supported.
Petter Gonçalves
February 6, 2020
Hello @Ian Johnsen
Unfortunately, the supported Slack and Jira integration do not have the functionality to create issues with required fields using the /jira create function.
We understand how this lack might impact the usability, that's why we created the following feature request to get this particular functionality improved:
Provide Values for Required Fields Using the "/jira create" command of the Jira Cloud for Slack integration
Feel free to vote and watch the suggestion to increase its priority and also receive notifications about any updates.
Let us know if you have any questions.
