Anything specific I need to configure to automate adding accounts to newly created tickets?
Saša Rosić-Milinković
So I have an issue where I want to add an Account via automation to our Bug tickets as they generally are logged and billed to one specific account.
I set the IF conditions for triggering the execution, and when setting up the THEN rule which is Edit issue -> Field: Account, I can't select any of the accounts that are configured within my project:
When I try to search for an account by name, I get an infinite loading animation and no results.
Is there something I need to do with my Project or Account setup, or is this an issue on the side of Jira?
Chris Rainey
May 14, 2024
Hey there,
What kind of field is Account here? Is this a User Picker field or is it something different?
Hi Chris,
The Account field is used to connect a Jira issue to a Billing Key that is configured in the Tempo app and is used for time logging/billing.
The billing key I want to use already exists and is used normally within my project, I just can't find/select it in the automation of the project itself.
