Is there anyway to create a template for tasks? Say I have a large task that I break out into 5 sub tasks and this process can be used for multiple sites. Instead of creating the same 5 tasks is there anyway to just pull from a template.
For sub task we have template mechanism.
for task level under epic, import option from spreadsheet may be an option.
There are several apps that allow you to do this. We use JSU on our workflow in the create transition. For certain types of issue types we auto generate sub-tasks when the issue is created. Issue template for Jira and scriptrunner are others that you could use as well.
Thanks for the reply Brant. Are those free or add-ons that you have to purchase? I was looking for something like you can do with Wrike, which is just copying and pasting tasks from one section to another.
Hey Charlie, did you ever get an answer. I too am a previous Wrike user and enjoyed creating templates we could duplicate and not have to recreate the wheel each time. Thanks!
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
