Sign up Log in
Application fails to restart.
Tyrone Fain
September 17, 2012
___ Plugin System Started _________________
2012-09-17 15:55:39,837 Spring executor 12 ERROR internal.dependencies.startup.DependencyWaiterApplicationContextExecutor Unable to create application context for com.pyxis.greenhopper.jira , unsatisfied dependencies: none
java.lang.IllegalStateException: Invalid BundleContext.
at org.apache.felix.framework.BundleContextImpl.checkValidity(BundleContextImpl.java:365)
at org.apache.felix.framework.BundleContextImpl.getServiceReferences(BundleContextImpl.java:307)
at org.springframework.osgi.util.OsgiServiceReferenceUtils.getServiceReferences(OsgiServiceReferenceUtils.java:159)
at org.springframework.osgi.util.OsgiServiceReferenceUtils.getServiceReferences(OsgiServiceReferenceUtils.java:195)
at org.springframework.osgi.util.OsgiServiceReferenceUtils.isServicePresent(OsgiServiceReferenceUtils.java:327)
at org.springframework.osgi.extender.internal.dependencies.startup.MandatoryServiceDependency.isServicePresent(MandatoryServiceDependency.java:82)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.doFindDependencies(DependencyServiceManager.java:287)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.access$700(DependencyServiceManager.java:40)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager$1.run(DependencyServiceManager.java:213)
at org.springframework.osgi.extender.internal.util.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:124)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyServiceManager.findServiceDependencies(DependencyServiceManager.java:209)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.stageOne(DependencyWaiterApplicationContextExecutor.java:239)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.refresh(DependencyWaiterApplicationContextExecutor.java:169)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:175)
at org.springframework.osgi.extender.internal.activator.ContextLoaderListener$2.run(ContextLoaderListener.java:716)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
2012-09-17 15:55:39,851 Spring executor 12 ERROR extender.internal.activator.ContextLoaderListener Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.pyxis.greenhopper.jira, config=osgibundle:/META-INF/spring/*.xml))
2012-09-17 15:56:16,376 main ERROR atlassian.jira.service.OfBizServiceConfigStore Unable to create a service config for service with the name : Subversion Revision Indexing Service
com.atlassian.jira.service.OfBizServiceConfigStore$ClassNotFoundServiceException: Could not find class: com.atlassian.jira.plugin.ext.subversion.revisions.RevisionIndexService
at com.atlassian.jira.service.OfBizServiceConfigStore.instantiateServiceContainer(OfBizServiceConfigStore.java:217)
at com.atlassian.jira.service.OfBizServiceConfigStore.getServiceContainer(OfBizServiceConfigStore.java:179)
at com.atlassian.jira.service.OfBizServiceConfigStore.getAllServiceConfigs(OfBizServiceConfigStore.java:159)
at com.atlassian.jira.service.DefaultServiceManager.loadServices(DefaultServiceManager.java:316)
at com.atlassian.jira.service.DefaultServiceManager.ensureServicesLoaded(DefaultServiceManager.java:306)
at com.atlassian.jira.service.DefaultServiceManager.getServices(DefaultServiceManager.java:81)
at com.atlassian.jira.upgrade.ConsistencyCheckImpl.getServices(ConsistencyCheckImpl.java:170)
at com.atlassian.jira.upgrade.ConsistencyCheckImpl.ensureSingleService(ConsistencyCheckImpl.java:524)
at com.atlassian.jira.upgrade.ConsistencyCheckImpl.checkMailListenerAndService(ConsistencyCheckImpl.java:385)
at com.atlassian.jira.upgrade.ConsistencyCheckImpl.checkDataConsistency(ConsistencyCheckImpl.java:224)
at com.atlassian.jira.upgrade.ConsistencyCheckImpl.checkConsistency(ConsistencyCheckImpl.java:213)
at com.atlassian.jira.upgrade.ConsistencyCheckImpl.initialise(ConsistencyCheckImpl.java:177)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:102)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:250)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:149)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:94)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:24)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:61)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:56)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:67)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:62)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:95)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4205)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at org.apache.catalina.core.StandardService.start(StandardService.java:525)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: java.lang.ClassNotFoundException: Class 'com.atlassian.jira.plugin.ext.subversion.revisions.RevisionIndexService' not found.
at com.atlassian.jira.plugin.DefaultComponentClassManager.constructEvenIfNotEnabled(DefaultComponentClassManager.java:151)
at com.atlassian.jira.plugin.DefaultComponentClassManager.newInstance(DefaultComponentClassManager.java:70)
at com.atlassian.jira.service.OfBizServiceConfigStore.loadServiceClass(OfBizServiceConfigStore.java:351)
at com.atlassian.jira.service.OfBizServiceConfigStore.instantiateServiceContainer(OfBizServiceConfigStore.java:212)
... 44 more
2012-09-17 15:56:16,450 main ERROR atlassian.jira.service.OfBizServiceConfigStore The class 'com.atlassian.jira.plugin.ext.subversion.revisions.RevisionIndexService' could not be found. This can happen when a plugin is uninstalled or disabled
2012-09-17 15:56:16,452 main ERROR atlassian.jira.service.OfBizServiceConfigStore A NoOp Service has been returned and hence 'Subversion Revision Indexing Service' will not do anything until fixed.
FagnerF
September 18, 2012
Hi Tyrone,
Take a look at the error below:
It occurs when the plugin was installed and then uninstalled incorrectly. Also The error that you are facing can occur If one removes the plugin from WEB-INF/lib without also removing the indexing service. You can check more details here.
Cheers
Sumit Kumar
July 13, 2014
