Applications Links not in Admin Navigation
Thomas McGunigale October 20, 2025
Applications Links are not displaying in my instance of Jira Admin Cloud account.
Instructions basic and appear easy to follow though path is not available. Trying to link to Monday.com
Any advice or path to resolution greatly appreciated
Link to other applications
Application links (sometimes called app links) allow you to set up links, share information, and provide access to certain resources or functionality across multiple Atlassian products. Linking Jira to other applications allows you to include information from these systems in Jira projects and issues.
For example, if you link Jira to Confluence, you can include pointers to wiki pages when creating or editing issues. Another common use case is to link Bitbucket Data Center with Jira; this allows you to view branches, commits, and pull requests that correspond to your Jira issues. In addition to Atlassian products, you can also link to external applications – for example, you can use an app that allows you to share ZenDesk or Salesforce data via an application link.
View application links
To view application links:
  1. Go to Administration > Applications.
  2. Select Application links. You’ll see the following page:
2 accepted
Mohanraj Thangamuthu
October 20, 2025
Hello, Good day. There are few changes added to the UI. Try Settings >> Jira apps >> Application links
Thomas McGunigale October 21, 2025
Thank you for the feedback! Got it
Like Mohanraj Thangamuthu likes this
Matteo Vecchiato
Hi @Thomas McGunigale ,
Not sure to understand your question. The application links section is accesible through this link: <yoursite>.atlassian.net/plugins/servlet/applinks/listApplicationLinks .
Hope it helps.
Thank you for the response. Very helpful and gets me to an area that was not visible or intuitive to navigate to.
