Approval in Jira Workflow (Premium)
Nayeemuddin Khan
August 6, 2024
I want to create Approval where approvers are dependent on another field. Like if Field A has value X, then Approvers will be 1, else if Field A has value as B, then Approvers will be 2 or 3 and likewise. I created the automation and the Approval Field and this field populates based on condition. However the Approval process does not pick the approvers for Approval... any help ?
John Funk
August 6, 2024
Hi @Nayeemuddin Khan
You should use the Approvers field for the approval if you are not doing that already. Then populate the Approvers field with users based on the value of Field A changing.
