Are the StonikByte dashboard gadgets experiencing an issue?
Dan Driscoll
I have one Jira Cloud instance where they are rendering fine.
I have another where every one is returning this pink box error message:
"There was an error verifying the jwt. Please contact your system administrator"
Danut M _StonikByte_
Hi @Dan Driscoll,
Thanks for contacting our support!
It turned out that the issue in question was specific to your Jira instance and a workaround was applied successfully.
Danut
Dan Driscoll
Thanks again Danut for the timely support yesterday!
ataranenko
March 25, 2024
@Danut M _StonikByte_
Looks like I have the same issue in my instance. Is there any public information available in regard to fixing these issues?
Hi @ataranenko,
If this happen in Jira Cloud, please try re-install the app by following these steps. All the existing app data will be preserved.
  • Go to Apps > Manage Apps
  • Click “Settings“ on the bottom of the page (under the apps list).
  • Check both option options Enable private listing and Enable Development Mode
  • Refresh the Manage apps page.
Thank you,
Danut Manda
