Ask to enter custom field when changing status
Kote Khutsishvili
Hi guys,
I want force a user to fill out custom field when he/she is doing a transition to a new status.
I've added validation and it works, but I want to appear pop-up during transition where a user can enter and submit to continue.
Is it possible?
Walter Buggenhout
September 20, 2017 edited
Hi @Kote Khutsishvili,
All you need to do, is associate a screen with the transition that holds the custom field you want the user to complete.
For more info, see screen design documentation
Then, add a validator to check whether the field is filled out.
Kote Khutsishvili
@Walter Buggenhout
Thank you, everything's set up right now!
Walter Buggenhout
Great! Well done!
Learn more
