×Hi,
I don't when and how I changed this, but this is not the default workflow.
How can I change to another workflow?
Thank you for feedback.
You can use the 'Add workflow' button on the top left to find the correct workflow, then assign it to 'Unassigned Issue Types' to update it :)
Be careful though, as it seems to affect 200+ projects according to your screenshot.
