Assign multiple Statuses to a column
Danich August 7, 2018
Hi Guys,
What are the chances of getting the functionality of adding multiple statuses to a column?
At the moment all I can see are statuses copying the columns we've created, however being able to add several statuses within a column would further "declutter" our board and allow for better / logical flow through our workspace.
Cheers
Dan
Eoin
March 1, 2021
This is being rolled out right now! :)
Marina Vafaei June 10, 2021
Hi Eoin, is this live?
I'm trying to allow "in progress" / "to do" / "done" statuses in 9 swimlanes for a kanban board and I can only have 3 lanes for each status right now.
blim
June 10, 2021
Hi @Marina Vafaei can you help me understand what each of your 9 swimlanes are?
Here’s a summary of what we released: https://community.atlassian.com/t5/Jira-articles/New-Features-Additional-Done-Statuses-Map-Multiple-Statuses-per/ba-p/1638591
Hi @blim thank you for your prompt reply.
Yes, it's:
  1. Not Ready
  2. Unprioritized
  3. Scoping
  4. Design
  5. Design Review
  6. Blocked
  7. Stakeholder Input
  8. Ready for Product Lead Review
  9. Ready for sprint
Ideally each lane would have all 3 statuses.
I tried creating custom statuses like "design done" following the linked instructions but my board only allows a total of 3 statuses (I don't see "design done" as a status I can use, so I am maxed at 3 cards for my kanban board).
blim
June 10, 2021
@Marina Vafaei can you attach a screenshot of your updated workflow with the "design done" status? Alternatively, feel free to file a support ticket
felix.weber
@blim am I correct that in company managed project it is still not possible to change the status within one column (per column we have multiple status)
- similar to @Haddon Fisher showed below
felix.weber
found by myself: still not possible: https://jira.atlassian.com/browse/JSWCLOUD-3573
blim
November 18, 2021
Hi @felix.weber & @Haddon Fisher : It is possible. Follow these steps:
1. Pick up a card on the board
2. Hover over the column name & drop the card into the "Transition To..." dropzone:Screen Shot 2021-11-19 at 10.06.05 AM.png
3. Drop the card into your desired status:
Try it out and let me know what you think! 😎
Monica Signer February 18, 2022
@blim  - the multiple status per column is working for my Completed column only.  I have 4 statuses that I have lumped into my "In QA" column - but when I move a card into that column, it only goes into the first of those statuses.  And I'm unable to move it from that first into the second, third, fourth......  so that I can then move the card into the next column.  (subtask 4 below is "In QA")
Jira - multi status per column.png Jira - trying to move between status in column.png
Like Everett Cavazos likes this
4 votes
ronan.considine
December 1, 2020
@Julien Femia
It has now been 2 years since this thread, has there been ANY movement to make multi-status columns available in next gen projects?
Thank you
Ronan
blim
February 15, 2021
Hello all,
We're rolling out the ability to add multiple statuses per column by the end of the month!
Let me know if you have any questions or concerns in the meantime. Otherwise, I will ping this ticket when we're rolled out to 100%.
Best,
Bryan Lim
Product Manager
Rey Wright
July 13, 2022
Hey @blim
Columns have multiple statuses now, but I can't see the specific status at a glance, because cards are not customizable in team-managed boards. Thoughts?
blim
July 13, 2022
@Rey Wright Definitely have been seeing this as a theme lately. We're hoping to kickoff work on custom card layout soon to help alleviate the problem https://jira.atlassian.com/browse/JSWCLOUD-17336
Feel free to watch that ticket and leave a comment!
Sonia Lamb
October 8, 2020
This feature is something I am looking at using now but it doesn't look like it has been implemented in the past 2 years. Unless I'm missing something and can't see where I can apply 2 statuses in 1 column on a next-gen board?
Roman Smolkin
January 26, 2024
For the columns that have multiple statuses mapped, could we have a filter to narrow down by statuses?  Either per column or per board.  Not sure why ther are only 3 filters, Epic, Label and Type.  Need a way to add more filters that are not "Quick Filters" but regular filters with drop-down multi-selects.
blim
February 25, 2021
@ronan.considine Argh, we hit some critical production bugs when trying to roll this out which caused some instances to have one status mapped to multiple columns. We have a fix in place and we're hoping to resume the rollout next week. *fingers crossed* let's check back in late next week.
ronan.considine
February 25, 2021
Hi @blim ,
Are you still on track to introduce these multiple status' in next gen products?
We are looking to implement this since your message early last week.
Thank you,
Ronan
Danich August 14, 2018
Brilliant @Julien Femia
Thanks for the update.
I'll keep checking in as advised.
Cheers!
Julien Femia
August 13, 2018
Hi @Danich,
thanks a lot for the feedback! This is definitely something that is on our list of things to do.
We will keep adding to and improving the Agility boards so keep checking in. However, if this is something that you need right now, maybe the classic kanban and/or scrum template might be a better fit for you.
Cheers!
Danich August 7, 2018 edited
Hi @Haddon Fisher,
Thanks for your reply - I'm aware of being able to do this in a Kanban / Scrum boards and what the functionality provides - But we are using the new Agility projects.
So being able to have the same function in the agility projects is what I'm asking for, sorry I should have made that clearer.
Cheers
Dan
Haddon Fisher
August 7, 2018
Hi @Danich,
Do you mean you need multiple statuses to show in the same column of a kanban or scrum board? If so, you can already do this from the "Column" section of a board configuration screen.2018-08-07_15-44-20.png
One thing to keep in mind - normally you can drag an issue from one column to another (if it has a transition in that direction between those statuses), however *you cannot drag an issue from one status to another in the same column*. Meaning that in the example above, if you assume that any status can transition to any other, you can move an issue from "Backlog" to "Blocked" and visa-versa, but *not* from "Blocked" to "Pending Acceptance" or "Waiting".
