Assign multiple values based on labels when issue is created
Katrina Pambid April 29, 2024
I would like to create an automation where in when issue is created, ill assign a value in multiple select field based on labels
For example
Labels: label1, label2, label3
Category: cat1, cat2, cat3
If a newly created issue have "label1" it should have "cat1" - this is straight forward
If a newly created issue have "label1" and "label2", it should have "cat1" and "cat2".
Any suggestions on how to do this is jira automation rule?
April 29, 2024
Hi @Katrina Pambid
What have you done thus far to solve this need?
If you have created a rule and it is not working as expected, please post images of the complete rule, the audit log details, the edit issue action, and explain what does not work.  These will provide context for the community to offer suggestions.
If you have not started a rule yet, I recommend trying to do so.  Successfully using automation requires learning and experimentation.  When one uses rules created by others without understanding them, they will be unable to maintain and improve them in the future.
To get you started on your rule, I suggest your rule could use conditional logic or repeated if / else blocks (or branches) to select the values for the multiple-select custom field.
Additionally, you will need to clarify your scenario to understand what happens when:
  • the multiple-select field already has values selected when the issue is created
  • there are no labels when the issue is created
  • the labels are manually changed after issue created
  • the values of the multiple-select field are manually changed after the issue is created
