Assignee REQUIRED
Alex
June 30, 2022
HOW TO MAKE A FIELD "assignee"  - required? on screen
3 accepted
Brant Schroeder
@Alex you have two options.
You can turn off allow unassigned issues in the general configuration.  Which will make it required on all issues and projects in Jira.
Or you can https://confluence.atlassian.com/jirakb/making-assignee-field-required-when-allow-unassigned-issues-is-turned-on-in-general-configuration-604209943.html
Alex
July 1, 2022
Solution!!!!!!! :
ADM ->workflow -> add validator
Nic Brough -Adaptavist-
July 1, 2022
That's another way to do it, yes, but it's a bit clunky.
Like # people like this
Marcel Kleinlütke
is this a JSU solution or out of the box?
June 30, 2022
Go to project settings and look for the "field configuration scheme".
Go into that, and look for the "field configuration" for the issue type you want to make it mandatory for (there may well only be one field configuration listed, in the default spot)
Go into the field configuration, you'll find it lists all the fields in the system (not just the ones in this project/issuetype).  Go find "assignee" and click the "mandatory" option to the right.
Be aware that field configurations are shared objects - there may be other projects and issue types using this one.
Daniel Lowe
This won't work per OPs screenshots the required link is missing for the assignee field.
John Schroeder
October 11, 2024
@Nic Brough -Adaptavist- Not possible, at least not in Data Center. You're back to @Brant Schroeder's first option. (Nice last name, btw.) It's either on or off at the System settings level. If it's off, "required" locked.assignee.png
