I just want to confirm one thing here, when I went from Create issue to Closed issue today.
During all state transitions, whether the record is assigned to other people will also be stored in the DB
Jira is an issue tracker. It tracks almost all change, as it should. (I only say "almost" because it doesn't have proper change control on comment edits or issue deletion, which I always turn off)
@Nic Brough -Adaptavist-
May I ask one question?
Are there records of assigned personnel, transitions between states?
Yes, as I said, it's an issue tracker - the whole point is that it keeps a history of change to issues (including who performed the change)
Sorry, I have one last question!
Will the records I mentioned above also be recorded in the DB?
All data is kept in the database, but you should never be looking there for it, it's really not suitable for reporting from.
