Associate a workflow / screen / issue type schemes by default to my new company-based projects
Jonathan Légal July 5, 2024
Hi everyone,
I would like to know how I can associate a workflow scheme, a issue type scheme, and a screen scheme to new projects created (e.g having a "by default" set up environnement).
I am asking because I always use the same workflow / issue type / screen schemes every time when I create a new company-based project.
Any ideas?
Many thanks,
Jonathan
Trudy Claspill
July 5, 2024
Hello @Jonathan Légal
When a Company Managed project is being created, at the point where you enter the project name there is an option to Share Settings.
If you check that box you will then be able to select from the existing Company Managed projects the project whose configuration you want applied to the new project. There are two important things to note:
1. This will share the schemes of the first project with the second project. They will be using the exact same schemes. Changes to the schemes will affect both projects.
2. This will share all the schemes; i.e. workflows, fields, screens, issue types, permissions, notifications. If you don't want to share all the schemes, then after the new project is created you would have to associate different schemes to the areas where you did not want to use shared schemes.
Jonathan Légal July 8, 2024
Thank you for your feedback Trudy. I will try that for my next project creation.
Angela Terilli
It's worth noting here that this option is disabled for those of us working on a Free Plan.
