Attaching Files to Project
Lincoln Kirk
March 8, 2016
We want to use the project container as our repository for housing files and documents related to an individual project. I see a way to do it in epics and issues but not directly to the project. Any assistance would be appreciated.
Michael Partyka
March 8, 2016
If that will be not enough you can use this plugin:
Michael Partyka
March 8, 2016
It is not possible to add attachment to project in a "straight" way.
You can always create an artificial issue type which will be one for project and attach to this issue you attachments (e.g. name it project attachments)
I hope that will help you
Michal
Nic Brough -Adaptavist-
March 8, 2016
JIRA doesn't have any file storage functions at project level, it's all about the issues.
I'm not aware of any add-ons that add that function, but I'd check the marketplace in case I've missed something.  I suspect you may have to write your own.  Although most of us link projects to Confluence spaces where you can document and store whatever you want, or have a project full of "project issues" where we can document the project.
Deleted user March 8, 2016
JIRA is an issue tracker, not optimized for files and documents so natively, JIRA can't do what you want. As you mentioned, you can attach files/docs to an issue which belongs to a project but that's it.
*JIRA attachments are not even optimized so that it "version controls" them you can even upload attachments with the same name).
Learn more
